Is this a healthy way of installing the jaw Coupling? As you can see the shaft is not fully inserted in the coupling due to some dimensional restrictions. Is it OK?
The key length will be designed for full length connection and could easily break when full torque is applied or fatigue out when multiple start stop occurs.
What percent is this inserted?
For me it's a maybe, depends on the length of engagement compared to the power /torque being transmited, a design check or a call to the manufacturer would clear it up for you.
