jrl802
Geotechnical
- Jul 13, 2010
- 19
Does anybody have experience in successfully utilizing “jetted” sheet piles as an installation method for sheet piles that were going to be used as part of a temporary retaining structure (TRS)? I have never encountered a need to use jetting for installation and have always been skeptical of using it for earth retention applications.
More background:
The firm I work for did some designs a few years ago for some Temporary Retaining Structures (TRS) consisting of internally braced sheet piles with walers and struts. I worked with a structural engineer colleague of mine on the design. The TRS will be used to maintain an open excavation for construction of an open flume u shaped concrete channel. The owner, a local utility/sewer district has retained our services during construction and the construction contractor is requesting a variance to use jetting to install the sheets even though the specifications clearly prohibit the use. My main concern is that the jetting will erode/disturb the soil such that the soil-structure interaction will be much different than what was assumed for the design thus rendering the TRS potentially unsafe. Am I off-base here?
More background:
