John_187
- Apr 21, 2018
- 68
Hello
There is a vertical turbine fire pump and there are some details I don't know about for how to install a jockey pump with this setup. The pump rep gave me a vague selection of a grade mounted jockey pump. The water level is 17 feet below grade in the pit below.
Is there some kind of automated primer valve for the suction line of the jockey pump to keep it full? Air purge valve? It should require a check valve too.
Should the suction line of the jockey pump stub directly into the sump pit for the vertical turbine fire pump?
Thanks for any help
Thanks for any help
