Thealanator
If one uses a jockey pump to keep a deluge water system pressurized, which is better: using a spillback valve for minumum flow or cycling pump off and on (assume that the start/stop setpoints are not spread too widely over the pump curve)?
Advantages/disadvantages for each method?
