Settingsun
- Aug 25, 2013
- 1,513
Hi all,
I've got an area of slab on ground with the shape shown below and would like suggestions for joint layout. The area is used for miscellaneous storage and will see some light vehicle traffic (eg 4WD/SUV with trailer). The client (local council) would like to use their standard 150mm (6") thick slab with SL72 mesh reinforcement and dowelled joints. SL72 = 7mm bars @ 200mm each way square mesh (just slightly heavier than 1/4" @ 8"). This is adequate for the loading and subgrade strength. Assuming the 150mm thickness, how would you lay out the joints?
(Imperial: 52' long by 18-32' wide)
Here's a blank version if anyone is enthusiastic enough to sketch.
