journal - geometry for constrain
MANox
PL
I have workpart and component in this assembly. Component has Symbolic Thread.
I want add concentric constraint between edge of start face of component, and selected edge in workpart.
Journal select compoenent with function SelectComponent from And it's work good.
And after I want select edge and I use this code:
Code:
 Dim theComponent As Assemblies.Component = Nothing
        If SelectComponent("select a component", theComponent) = Selection.Response.Cancel Then
            Return
        End If
        Dim prototype As Part = theComponent.Prototype
        Dim edges() As Edge
        Dim edge1 As NXOpen.Edge
        For Each feature1 As Features.Feature In prototype.Features
            'lw.WriteLine(feature1.GetType.ToString)
            If feature1.FeatureType.Equals("SYMBOLIC_THREAD") Then
                If feature1.GetType.ToString() = "NXOpen.Features.Feature" Then
                    'lw.WriteLine(feature1.GetType.ToString())
                    Dim data As UFModl.SymbThreadData = New UFModl.SymbThreadData()
                    theUfSession.Modl.AskSymbThreadParms(feature1.Tag, data)
                    Dim face2 As Face = Utilities.NXObjectManager.Get(data.cyl_face)
                    edges = face2.GetEdges()
                    'lw.WriteLine(face2.Tag)
                ElseIf feature1.GetType.ToString() = "NXOpen.Features.Thread" Then
                    'edges = feature1.GetEdges
                    Dim threadBuilder As ThreadBuilder = workPart.Features.CreateThreadBuilder(feature1)
                    'Dim face As Face = CType(threadBuilder.CylindricalFace, Face)
                    Dim startObject1 As SelectDisplayableObject = threadBuilder.StartObject()
                    Dim selection As DisplayableObject
                    Dim view1 As NXOpen.View
                    Dim point1 As Point3d
                    startObject1.GetValue(selection, view1, point1)
                    If selection.GetType.ToString = "NXOpen.Face" Then
                        Dim face As Face = CType(selection, Face)
                        Dim edge = face.GetEdges
                        MsgBox(edge.Length)
                    End If
                End If
                If Not edges Is Nothing Then
                    'lw.WriteFullline(edges.Length)
                    edge1 = edges(0)
                End If
            End If
        Next
Generaly, I can find edge.
The problem is:
Code:
 Dim constraintReference1 As NXOpen.Positioning.ConstraintReference = Nothing
        constraintReference1 = componentConstraint1.CreateConstraintReference(theComponent, edge1, False, False, False)
error message: NXOpen.NXException: The entity is not a valid constraint w NXOpen.Positioning.Constraint.CreateConstraintReference(NXObject movableObject, NXObject geometry, Boolean usesAxis, Boolean isIndirect, Boolean usePortRotate)w NXJournal.Main...
I think I must take geometry from component, not from prototype?
Maybe other error?
I somebody can help me - please help!!!!.
Best regards
MANok
NX2006
TC14
Many thanks cowski,
one line, and I've been looking at it for as long time...
Best regards
MANok
NX2006
TC14
