I'm stumped on this one.
Probably the simplest one I've needed.
I use journals to set Drafting Preferences for Font, Arrow Size, etc. Everything having to do with text. Here's a sample of one of them.
I just want to select a dimension or note and update it. Keep doing that until I crash out of the journal.
I've done similar journal for body colors, etc.
I am just drawing a blank on this one.
Thank you for all the help in the past!
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
' Menu: Preferences->Drafting...
Dim TEXTSIZE = .0625
Dim TEXTSIZEHALF = TEXTSIZE/2
'Dim FONTNAME = "Arial"
'Dim FONTNUMBER = 1
'''''' Arial's number = 1
Dim FONTNAME = "Verdana"
Dim FONTNUMBER = 5
'''''' Verdana's number = 5
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim preferencesBuilder1 As NXOpen.Drafting.PreferencesBuilder = Nothing
preferencesBuilder1 = workPart.SettingsManager.CreatePreferencesBuilder()
preferencesBuilder1.AnnotationStyle.LetteringStyle.DimensionTextSize = TEXTSIZE
preferencesBuilder1.AnnotationStyle.LetteringStyle.GeneralTextSize = TEXTSIZE
preferencesBuilder1.AnnotationStyle.LineArrowStyle.ArrowheadLength = TEXTSIZE
preferencesBuilder1.AnnotationStyle.LineArrowStyle.TextOverStubFactor = TEXTSIZE
preferencesBuilder1.AnnotationStyle.LineArrowStyle.StubLength = TEXTSIZE
preferencesBuilder1.AnnotationStyle.LineArrowStyle.TextToLineDistance = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LineArrowStyle.FirstPosToExtensionLineDistance = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LineArrowStyle.SecondPosToExtensionLineDistance = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LineArrowStyle.LinePastArrowDistance = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LineArrowStyle.DatumLengthPastArrow = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LetteringStyle.ToleranceTextSize = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LetteringStyle.TwoLineToleranceTextSize = TEXTSIZEHALF
preferencesBuilder1.AnnotationStyle.LetteringStyle.AppendedTextSize = TEXTSIZE*.9
Dim nXObject1 As NXObject
nXObject1 = preferencesBuilder1.Commit()
theSession.SetUndoMarkName(markId1, "Drafting Preferences")
preferencesBuilder1.Destroy()
Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim preferencesBuilder2 As NXOpen.Drafting.PreferencesBuilder = Nothing
preferencesBuilder2 = workPart.SettingsManager.CreatePreferencesBuilder()
Dim fontIndex1 As Integer = Nothing
'fontIndex1 = workPart.Fonts.AddFont("Arial", NXOpen.FontCollection.Type.Standard)
'preferencesBuilder2.AnnotationStyle.LetteringStyle.GeneralTextFont = 1
fontIndex1 = workPart.Fonts.AddFont(FONTNAME, NXOpen.FontCollection.Type.Standard)
preferencesBuilder2.AnnotationStyle.LetteringStyle.GeneralTextFont = FONTNUMBER
Dim fontIndex2 As Integer = Nothing
'fontIndex2 = workPart.Fonts.AddFont("Arial", NXOpen.FontCollection.Type.Standard)
'preferencesBuilder2.AnnotationStyle.LetteringStyle.DimensionTextFont = 1
fontIndex2 = workPart.Fonts.AddFont(FONTNAME, NXOpen.FontCollection.Type.Standard)
preferencesBuilder2.AnnotationStyle.LetteringStyle.DimensionTextFont = FONTNUMBER
Dim nXObject2 As NXOpen.NXObject = Nothing
nXObject2 = preferencesBuilder2.Commit()
theSession.SetUndoMarkName(markId2, "Drafting Preferences")
preferencesBuilder2.Destroy()
End Sub
End Module
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main(params() As String)
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Dim myBody As Body
Do Until SelectBody("select a body", myBody) = Selection.Response.Cancel
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = True
displayModification1.ApplyToOwningParts = False
displayModification1.NewColor = 108
'displayModification1.NewTranslucency = 50
Dim objects1(0) As DisplayableObject
objects1(0) = myBody
displayModification1.Apply(objects1)
displayModification1.Dispose()
Loop
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
Function SelectBody(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim title As String = "Select a solid body"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim cursor As Point3d
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
title, scope, selAction, _
includeFeatures, keepHighlighted, selectionMask_array, _
selobj, cursor)
If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
End Module
