Journal works OK but throw warning BC42020 when compiling.
Ehaviv
Computer
IL
Hi
Compile throw this warning:
Code:
warning BC42020: Variable declaration without an 'As' clause; type of Object assumed.
 Public Function select_text_file(ByRef partFullPathName) As DialogResult
For this function:
Code:
   Dim ofd As OpenFileDialog = new OpenFileDialog()
   Dim result As DialogResult
   ofd.Title = "Select assembly part"
   ofd.AddExtension = true
   ofd.DefaultExt = "prt"
   ofd.Filter = "Files(*.txt;)|*.txt;"
   ofd.FilterIndex = 1
   ' start browsing at current folder, uncomment for any other default directory
   ' ofd.InitialDirectory = GetEnvironmentVariable("UGII_BASE_DIR")
   ' ofd.InitialDirectory = GetEnvironmentVariable("UGII_BASE_DIR") + "\Moldwizard"
   ' ofd.InitialDirectory = "c:\mypath1\mypath2"
   result = ofd.ShowDialog()
   partFullPathName = ofd.filename
   ofd.Dispose()
   Return result
 End Function
Please can somone help to get rid from this compile warning.
Thank you.
Assuming "partFullPathName" is a string:
Code:
Public Function select_text_file(ByRef partFullPathName [highlight #FCE94F]as String[/highlight]) As DialogResult
Edit as necessary to match the type of "partFullPathName".
www.nxjournaling.com
Hi Cowski
Thank you very much.
Double eyes is better.
I was confused with the As of
Dialogresult and I don't see the
lack of the As String.
Thank you.
