Journaling, Display Part Help
kr7530
Automotive
I am trying to get a journal to cycle through an assembly with no luck.
I get the error: "Failed: NXOpen.NXException: This operation can only be done on the display part
at NXOpen.Layer.LayerManager.GetAllObjectsOnLayer(Int32 layer)"
I am assuming I need to make the prototype part the displayed part but am unsure as to how.
Any help would be greatly appreciated!!!!
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Collections.Generic
Imports NXOpen.UI
Imports NXOpenUI
Imports NXOpen.Utilities
Imports System.Windows.Forms
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
lw.Open
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'*** end of code to process root component
ReportComponentChildren(c.RootComponent, 0)
else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
lw.Close
End Sub
Sub reportComponentChildren( ByVal comp As Component, _
ByVal indent As Integer)
For Each child As Component In comp.GetChildren()
'_____________________________________________________________________________________________
Dim workPart As Part = child.Prototype.OwningPart
Dim lw As ListingWindow = theSession.ListingWindow()
Dim layerObjects2() As NXObject
lw.Open
lw.WriteLine(child.Name)
'checking to see if refereset exists--------------------------------------------------------
Dim BODYRefSetCount As Integer
Dim ModelRefSetCount As Integer
For Each myRefSet As ReferenceSet In workPart.GetAllReferenceSets()
If myRefSet.Name = "BODY" Then
layerObjects2 = workPart.Layers.GetAllObjectsOnLayer(150)
If layerObjects2.Length > 0 Then
myRefSet.RemoveObjectsFromReferenceSet(layerObjects2)
Else If layerObjects2.Length = 0 Then
'MessageBox.Show("No geometry on layer 150")
End If
BODYRefSetCount = 1
Else If myRefSet.Name = "MODEL" Then
myRefSet.RemoveObjectsFromReferenceSet(myRefSet.AskAllDirectMembers())
Dim refsetMembers() As NXObject = myRefSet.AskMembersInReferenceSet()
ModelRefSetCount = 1
End If
Next
'populating reference set--------------------------------------------------------------------
layerObjects2 = workPart.Layers.GetAllObjectsOnLayer(1)
For Each myRefSet4 As ReferenceSet In workPart.GetAllReferenceSets()
If myRefSet4.Name = "MODEL" Then
Try
Dim body1 As Body = CType(workPart.Bodies.FindObject("BLOCK(0)"), Body)
Dim components1(0) As NXObject
components1(0) = body1
myRefSet4.AddObjectsToReferenceSet(components1)
Catch ex As NXException
'MessageBox.Show("Block(0) does not exist, add detail to reference set manually")
End Try
End If
Next
'MessageBox.Show("No entities exist on layer 1")
End If
lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
'*** end of code to process component or subassembly
if child.GetChildren.Length <> 0 then
'*** this is a subassembly, add code specific to subassemblies
lw.WriteLine(New String(" ", indent * 2) & _
"* subassembly with " & _
child.GetChildren.Length & " components")
" + Active Arrangement: " & _
child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
'*** end of code to process subassembly
else
'this component has no children (it is a leaf node)
'add any code specific to bottom level components
end if
reportComponentChildren(child, indent + 1)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
Got it
theSession.Parts.SetDisplay(workPart, False, True, loadStatus)
