Journaling help needed - Colouring and defining attributes
Nome737
1
Hello together
I have seen the following post for colouring surfaces.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module changeColorOfPreSelectedFaces_v2
	Dim theSession As Session = Session.GetSession()
	Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
Sub Main()
	'' Integer variable to store color code in.
	Dim newColorCode As Integer = 114
	newColorCode = Convert.ToInt32(211)
	'' The selectFaces method takes an NXobject array by reference
	Dim selectedObjectsArray() As NXObject
	SelectFaces(selectedObjectsArray)
	'' Need to recast the face NXObjects to Displayable objects
	Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject
	For i As Integer = 0 To selectedObjectsArray.Length - 1
		faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
	Next
	'' A display modification object is used to change to color of the faces.
	Dim changeFaceColor As DisplayModification = theSession.DisplayManager.NewDisplayModification()
	With changeFaceColor
		.ApplyToAllFaces = False
		.NewColor = newColorCode
		.Apply(faceArray)
		.Dispose()
	End With
End Sub
Sub SelectFaces(ByRef selectedObjects As NXObject())
	Dim ui As UI = NXOpen.UI.GetUI
	Dim message As String = "Select faces"
	Dim title As String = "Select faces"
	Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
	Dim keepHighlighted As Boolean = False
	Dim includeFeatures As Boolean = False
	Dim response As Selection.Response
	Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
	Dim selectionMask_array(0) As Selection.MaskTriple
	With selectionMask_array(0)
		.Type = UFConstants.UF_solid_type
		.Subtype = 0
		.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
	End With
	Response = ui.SelectionManager.SelectObjects(message, title, scope, selectionAction, includeFeatures, _
			keepHighlighted, selectionMask_array, selectedObjects)
	If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
		Return
	End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
	GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
Is it possible to extend this journal by assigning an attribute to the selected surfaces?
Thank you very much for jour help!
Nome
Hi Nome,
To add an attribute "testAttribute" populated as "hello", try the following lines after "End Width" and before the first "End Sub":
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim objectGeneralPropertiesBuilder1 As NXOpen.ObjectGeneralPropertiesBuilder = Nothing
objectGeneralPropertiesBuilder1 = workPart.PropertiesManager.CreateObjectGeneralPropertiesBuilder(selectedObjectsArray)
Dim objects4(-1) As NXOpen.NXObject
Dim attributePropertiesBuilder2 As NXOpen.AttributePropertiesBuilder = Nothing
attributePropertiesBuilder2 = theSession.AttributeManager.CreateAttributePropertiesBuilder(workPart, objects4, NXOpen.AttributePropertiesBuilder.OperationType.None)
attributePropertiesBuilder2.SetAttributeObjects(selectedObjectsArray)
attributePropertiesBuilder2.Title = "testAttribute"
attributePropertiesBuilder2.StringValue = "hello"
Dim changed1 As Boolean = Nothing
changed1 = attributePropertiesBuilder2.CreateAttribute()
Dim nXObject1 As NXOpen.NXObject = Nothing
nXObject1 = objectGeneralPropertiesBuilder1.Commit()
attributePropertiesBuilder2.Destroy()
