JT Versions
phillpd
780
If I export a JT file from NX9, is there a minimum version of JT2Go that will open it ?
NX 6.0.5.3, NX 9.0.2.5
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
I think it is depending o the JF file version. In the config file (tessUG.config) you can
define any(?) JT file version. If you only have a certain JT2Go version that can read only
JT version 8, you can set your converter to write JT version 8.
regards
That's what I thought.
For NX6 and NX9, both config files are using ... JtFileFormat = "9"
However, JT2Go 8.3.2 won't open the NX9 exported JT file.
NX 10 (Testing)
can you verify that the JT version of both is "9"?
Does NX6 even support JT 9? Mayb NX6 does not creat JT9 while NX9 does create JT9?
