Jump over piping
nabeel3
145
Dear All
what is a Jump over piping?
Example:- Jump Over for Pump Suction line (16” size)
'Jump over' could be a 'runaround' or small diameter bypass of some sort. More context would help.
Usually means exactly what it says, I.e.the pipe "jumps over" another pipe sitting at the same elevation.
Soe a U shaped thing with 4 90 degree elbows.
From my refinery drawing office days many years ago a jumpover was a piping interconnection requested by operations in order to push product somewhere not originally intended.
In context to jacketed piping, a jumpover is used wherever the jacket pipe is terminated e.g. flanges, valves. The jumpover consist of the jacket fluid which is used to heat the core run.
Dear all
Thanks for your inputs. This was an enquiry we received from a petrochemical plant for a procurement and build work. I couldn't see any definition in the contract documents from the owner. Owner wants to change the service of a tank. Contractor has to install new piping from the pump discharge.
I think that fits my description, I.e. the pipe"jumps" from its current routing within a low level pipe rack or sleepers to another location.
So often a complex tight tie in.
