joemarch
- Jul 20, 2004
- 54
Is it a right assumption to model the k-bracing in a frame as tension only members? I've entered a frame into RISA and specified the k-braces to be tension only members. In the results it shows the members taking compression. Should I model the bracing as compression members?
