k factor
mitchiegalve
1
where do i get the k factor of y strainer? and also other valve? and what is the different between kf and kv
The vendor?
By K do you mean a resistance coefficient like Crane uses? I've not seen K factors for strainers, I've seen some vendors provide a Cv for their strainers so you calculate the dP like a control valve in liquid service. Others will provide a curve for flow versus pressure drop.
I don't know what kf and kv stand for.
Search threads for Cv and Kv for this forum. Kv is the 'european' (metric based) flow coefficient, and as Cv has to be measured for each single valve or construction.
Values are normally given from manufacturor.
Kf and K? Depends on context and orogin of definition! I have seen vseveral variations of use of thesse abbreviations / letters. Also: as alomst any strainer can have a number of different inside 'filter' (number or diameters of holes, thread thickness and idstance etc.) you have to go to the 'source' to find the correct answer.
And as stanier says: fluid, flud condition and filter condition?
