Hi all, I'm running a metal cutting simulation with Abaqus/explicit. Generally, I use the Kinematic contact between the tool surface and workpiece surface(node-set), but when I set the rigid tool to rotate, it suggests that I can't use kinematic contact anymore, I have to use penalty contact. I wonder whether using penalty contact affects the accuracy of the simulation results or not?
