Kinematics
1oldcaduser
Automotive
Jun 3, 2005
79
Has anyone got access to docs on kinematic design. I haven't used this workbench much and would appreciate some help
Thanks for the answer but I have access to these help files. What I have is a 4 bar linkage with a kinematic set and a small separate rotation attached to one of the links and I can't get both sets to work in sync. Can anybody assist
So you have 2 kinematic mechanisms and you want to run both at same time? If that is the case, Make a simulation for each mechanism, then create a sequence.
Thanks for the info. I bought a kinematics book and it covers the setting up of mechanisms very well but it did not mention sequencing, sub assembly kinematics or dress up at all. To me that is all part of the same functionality. Anyone no of docs that cover all the kinematic functions.
