We are in search of the largest bipolar HVDC system based in VSC technology to support a transmission capacity targeting around 1400 MW at ±320 kVdc using submarine and UG land cable including a neutral grounded metallic return.
[ul]
[li]Does anyone know what is the largest converter station available based on VSC technology?[/li]
[li]Does the converter station require a large grounding electrode near the converter station even if the metallic grounded return will be used with a permanent connection to the earthing grid?[/li]
[/ul]
[ul]
[/ul]
