.las file 1
Lars1978
327
Hi All,
Can anybody tell me how to import a .las file into NX12 ?
This las file is the output of an 3D scanner.
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
Don't think that NX is capable of doing this. Most 3D scanners however should be able to generate an STL file. This is no problem for NX to import.
Or you need to find an online translator for .las to .stl
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
There is a "steinbichler" import. If i understand it correctly, that is a common 3d scan format.
Tomas
Hi All,
Please find the .las file attached. (see link)
I've found a converter which translates the .las file into a point cloud. (LAStools)
To import this file (.txt) takes a long time.
Which genius can help me to make a usable .stl file out of the .las.
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
Tomas,
What do you mean with a steinbecher import? Is this an extra NX module?
Lars
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
Tomas,
Don't think this is the solution. This translater asks for .ac files.... :(
Lars
NX12.0.1.7 native
Solid Edge ST10
Inventor
I was rather hoping that your scanner could output a steinbichler file instead of .las
Tomas
