Hello all,
I have a roof structure consisting of glulam beams supporting roof purlins (bottom of purlin is connected to the top of the glulam beam). Glulam is 6.75"x21". Left end of glulam is cantilevered over a beam a distance of 3'-4". Right end of the glulam is cantilevered over a beam a distance of 6'-0". There is one column supporting the bottom of the glulam resulting in a two span condition between beam supports at the cantilever. I have a 11' span and a 19' span each side of the middle support column. ----^--------^-----------^----- Where the ^ is the supports. Originally, I was providing kickers at the interior column location to brace the bottom of the glulam; however, the arch is wanting a "clean" look and does not want these kickers. What are my options in order to eliminate any "kickers" at interior columns?
Thank you and have a great day.
