I have a W12 beam split into two spans of 20ft each with column support between two spans. The outer ends of both spans are simple supported. I am removing a column support, which results the beam into one span of 40ft long. I am adding WT above top flange of W12 beam. The W12 beam is braced for lateral movements near the top (compression) flange at every 4ft spacings. My questions are:-
1. Can the current lateral brace at W12 beam be used as a brace to resist Lateral torsional buckling of the new cross-section after adding WT? In other words, if I want to calculate moment resistance of beam reinforced with WT, can I account for existing lateral brace in calculating effective braced length of beam?
2. The stem and flange of WT section are stiff enough not to locally buckle. In other words, it meets width/thickness limitation criteria of standard that ensures that the components of section won't buckle individually. Do you see any other type of failure as a major concern, other than lateral torsional buckling?
