I am learning about pressure vessel design for external pressure (vacuum). Just doing the exercise. Not designing the actual vessel.
I came across cautionary note in UG-29 (a) that the stiffening ring may be subject to lateral buckling. And this should be considered in addition to the requirements for Is & Is’.
I understand that the Is & Is’ per UG-29(a) are required for global buckling of pressure vessel.
How the ring will see lateral buckling load? I am wondering how I go about lateral buckling check of stiffening ring itself? Any ideas out there?
Thanks!
Thanks!
