SocklessJ
- Aug 24, 2017
- 45
I have been tasked with adding a large 2-story RTU platform to the roof of an existing steel building. This roof is made from structural steel shapes, which are sloped for drainage.
The units are quite heavy (60 kip total), so I intend to attach to the existing columns by welding thick cap plates to the column flanges. However, I’m worried about lateral loads. The roof beam connections might not have the axial capacity to drag out the lateral load to the horizontal trusses that comprise the roof diaphragm. I don’t have connection details yet, but I’m hoping that they didn’t use really thin clip angles.
Does anyone have a good suggestion for improving the axial capacity of existing beams? I guess I could increase the size of my cap plate and weld it to the top flanges of the intersecting beams. I could then add flange plates to the bottom flanges. This would create a moment connection, which would need to be analyzed as such. Has anyone run into a situation like this before? This is an industrial structure, but I know heavy RTUs are frequently placed on commercial buildings.
Attached is a conceptual sketch (without reinforcement)
