I am designing a home on the east coast that will be supported on 8x8 timber piles. After reading FEMA publications it appears the preferred method of bracing the piles is diagonal bracing. Does anyone have a design example of this. It seems like the bolted connection to the pile is the "weak link" with (2) 3/4" diameter bolts and I dont see any way I could possibly get more than a couple thousand pound tension load into the 2x10 brace which is only a small fraction of the lateral load. This is particularly problematic on the street front elevation as they want to park vehicles and there is really only room for one braced bay. Is it more realistic to add enough piles and design each of the piles for an equal amount of the lateral load as cantilevered columns?
