Lateral pressures due to stacked snow:
Has anyone had to design for lateral pressures due to piled or stacked snow? We are designing a large apartment complex which surrounds a roughly 120-ft by 300-ft 4-story precast concrete garage with a "snow-chute" for clearing snow from the roof. The garage is in the center of the apartment complex, so snow cannot be simply blown over the side. The snow is loaded into a vertical shaft (the snow chute) which has an opening at the ground level where another bobcat can remove it.
The snow chute is 44-ft high, and the precast engineer is asking what the lateral forces are for design of the chute walls.
Has anyone encountered this? I am looking for some guidance to determine the lateral pressures that can develop, and the design basis to provide safe, reliable design values for the precast engineer.
Thank-you!
Thank-you!
