Learning pipeline
sreeku10
Hi all
I want to join as a pipeline engineer in any Direct engineering companies in Middle East,
so right now one can say i am a rookie in the field,
all I have now is a B-tech in mechanical engineering and an passion to learn.
So can you Guys help me from where to start and how should I progress my career
also please mention any text, courses, YT channels,
ku10
There are numerous courses, online or in universities et.
You could start by understanding pipeline design codes ASME B 31.4 and 31.8. Free older versions are generally found online.
The middle east tends to use these .
Also see if you can get earlier versions of the IPLOCA "The road to success". You can sometimes find version 3 available.
try pipeline construction companies first I would say.
thank you for the reply i will try my best
HI:
firstly you need to join any contracting company on a initial level . before joining to any online course you should try to learn Welding and pipe fittings and supports basics. After atleast six months , you may start with some courses as advised in above .
it's good advice
