Am I missing something here? If I add a path for standard parts as a library I then cant modify any of those parts in the Library (error of part not checked out to me)? Otherwise remove the library path and have to manually path each part that isn't directly underneath that project folder?
Am I doing something wrong? That seems like a huge pain in the ass. Everything changes, even libraries, and you should be able to modify parts in one. Or how else do you call in parts that aren't in the project folder besides getting prompted each time you open an assembly.
