PV design Engr
I have an issue with respect to lifting trunnion design in one of my column. This is SS304L column of 2.3 m dia and 30 mts length. My top shell course thickness is 10mm for 8m length. Our client spec calls for design of lifting trunnion design with dressed condition and impact factor of 2. My erection weight of the equipment is around 82 tons. The lifting trunnion is placed at 25 mts from tanline to pass the rigging check. The lifting trunnion design has become a very challenge as this 500mm in length. Has anybody has the experience using solid lifting trunnion as my construction standard uses a hollow pipe of 24" size for this weight.My manufacturer proposes to use solid trunnion but i am worried about the distortion in the shell.
