MJC6125
- Apr 9, 2017
- 120
I'm working on 3-story office building with composite steel floor structure and light gauge steel stud exterior walls with brick veneer and punched openings (max opening width = 14'). Most of my experience with steel framed buildings are 2-story or shorter structures. So, I'd like to get the opinions of others on a couple items. See elevation view below for reference.
1. The plan is to balloon frame the exterior stud walls (studs bypass the floor slab and steel structure). Is this what you would typically do for a building like this? Can all of the exterior studs be supported vertically at the foundation and just clipped off with slip clips at the levels above? Or would you need to support the studs vertically at any of the upper levels for any reason? A couple things to note are that this is Seismic Design Category B (so seismic shouldn't be a big issue) and the overall wall height from the first floor is 44'.
2. We have brick veneer that exceeds the 30' max height limit per the ACI 530 prescriptive requirements, so I believe a shelf angle will be required. Would you weld this shelf angle back to the light gauge steel stud framing or back to the steel superstructure? If it is attached to the steel superstructure, deflection limits on the edge beams would have to be much more stringent. Would you ever consider not providing the shelf angle and letting the brick stack 44'? I know I've seen some posts on this website that allude to that, but I imagine it's not the industry standard.
3. Any good references for these types of details and this condition are much appreciated.
