Line cleanup ?
closer9
108
Not quite sure how to ask this, but I'm wondering if there is a way to cleanup, consolidate or remove overlapping lines. For example a 3D Pro-e file is converted to DXF and opened in AutoCAD (v2002 here) and all lines that were on planes normal to the page still appear. When brought into a plant layout this creates a nightmare number of objects, and is also hard to work with... Does anyone know a way to cleanup such a situation?
thanks...
You can select short lines, small radius arcs etc by using the PSELECT (filter funnel icon) tool on the properties dialog box.
Autocad 2000 also has a separate FILTER command.
After preselecting them, you can erase them.
ERASE, Select Objects P (for previous) Enter.
Can you rotate the model 90 degrees about the x-axis and erase crossing all lines above and below 0,0,0?
