Again I'm with TD2K here. We've used pipe and tubing in clean liquid services at velocities far greater than 15 ft/s and never seen evidence of erosion. River water with sediment in it? Slurries? Situations where there's risk of erosion-corrosion? Sure- those have their own velocity rules which vary from service to service.
For clean liquids, 15 ft/s is at the upper limit of the economic velocity in piping due to pump energy cost, NOT due to erosion risk. When you're wasting the energy anyway, i.e. in a pressure let-down train, as long as the control valve is still the controlling resistance in the circuit, we have no problem letting pipe take more of the pressure drop by allowing velocities to climb well beyond 15 ft/s.
We also make the switch from 2" to 3" pipe only if velocity goes beyond 15 ft/s, where available pressure drop permits. The capital cost jump in linesize from 2" threaded to 3" welded is huge- vastly greater than from 3" to 4" etc.
The velocity in pretty much every orifice plate, control valve trim etc. we specify is well above 15 ft/s, as are the exit nozzles of most centrifugal pumps. We don't see these wearing out quickly in clean liquid services.
