Firerunner
I need help with a lisp routine I want to try, I don't know that much about Autolisp. The last time I did anything with it was years ago.
Here we go. I would like to have the user pick the devices (blocks) in order, then pick a point to start. AutoCAD would then insert from the start point, the blocks that were selected in a horizontal fashion with a 6" gap between them. Also, The block would have the attributes of of the selected block.
I not even sure where I should start.
