CheemaJ
Chemical
- Mar 8, 2019
- 21
There is an area where we would like to install a number of steel vessels, supported off legs, for storing liquids. Some core sampling was carried out last week (attached a couple of photos) and we managed to get a measurement of the slab thickness in a couple of different locations. It is around 250mm thick (10 inches). There appears to be steel reinforcement present as well. I don't yet have any information on the substrate unfortunately.
The tanks will weigh a maximum of 37,000 kg (37 tonnes). The diameter of the tanks is around 3m (10 ft). Each tank will be supported off 4 legs. There will be plates welded to the bottom of the legs to spread the load (size can be varied according to requirements).
Not being well versed in structural engineering I was wondering if someone could offer an insight into how I'd check whether the slab is capable of supporting this kind of weight.
Many thanks
Many thanks
