(Load manipulation) Advice/Steer request!
Studentforlife
Aerospace
Aug 28, 2020
11
Hello all,
I hope that all my fellow engineers are keeping well and safe. I was looking to get some advice from well-seasoned aircraft stress engineers on this forum.
I have recently come across a problem where I have loads defined for points 1,2 and combined moments at the location where the structure is fixed (points 3,4). I hope you can see the picture which I have tried to attach. I am now assessing Section a-a of the structure for stability and strength (by calculating section properties: moment of inertia, neutral axis etc.).
Would it be acceptable or conservative if I took a 60/40 load and moment split to obtain the loads at Section A-A? So the loading will look something like (Fx1+Fx2)x0.6, (Fy1+Fy2)*0.6 ... Mx x (0.6), My x(0.6) and so on?
Or
Do you suggest I resolve loads from Points 1 and Point 2 onto the neutral axis and obtain loads of Section a-a that way? Please keep in mind that the structure is fixed at points 3,4.
What are your thoughts? Looking forward to hearing from you.
Many Thanks
Sam
Are the forces acting on the solid plate/medium that is fixed to support points 3 & 4? What is the structural rigidity of the plate/medium?
Many thanks for your response.
No forces acting at points 3 and 4 (it's fixed at these locations so will only see reaction loads).
The structure is metal (aluminum) to be more precise, so will have high structural rigidity.
Then, I think you should resolve the forces according to rigid body with fixed edge supports to obtain reactions at points 3 & 4 respectively.
What are the co-ordinates of points 1, 2, 3 and 4? You need to know that before anything can be determined. Even then, the problem is indeterminate because supports 3 and 4 are fixed and the stiffness of the structure is unknown.
Edit: Remove one of the supports and the structure is easily solved.
BA
The coordinates of the points and all the necessary mechanical properties for material are known.
To you maybe, but not to us. The 60/40 rule is not valid. It could be conservative for some reactions and unconservative for others.
BA
I know what you mean! Thanks for your advice. I will have to revisit the boundary conditions, as the points 3,4 are actually bolted onto a structure which is free to move in the z direction. Sorry if my response sounds vague or unclear as the requirements for this test aren't clearly defined, so I'm having to make some assumptions.
If the rigid plate is loaded forces in all three dimensions, you would need more than two support points to be stable. I think engineering mechanics is the best tool to solve this problem. The next will be a computer program, if rigidity of the plate is questionable, such as a large, but relatively thin metal plate.
Thanks for all your responses as it gives me a good steer on how to approach this problem!
