load options
MorTamir
Aerospace
I am trying to open an assembly with parts specific to the project folder, and additional fasteners from fasteners folder and reference parts from my library folder. altogether 3 folders that one of them is changing from project to another.
When I open the assembly via "search folder" the items from the project folder are not loaded. And when I open it via "form folder", the fasteners are regenerated and find them selves, which is OK, but my reference parts aren't loaded.
I am Using NX8.5.
Is there a way to overcome this issue?
Thanks in advance,
Mor
Try to use the Load option as...
As Saved
Loads the same set of components as when the assembly was last saved.
Mathi K
Mathi,
Thank you,
I will try it.
Mor
