Javiduc
- Mar 2, 2016
- 52
Sometimes I want to copy an assembly (For example Assembly "A.A") that I have used or created in a previous project (Project A) to be used in a new project (Project B) . In other software, I was used to copy in windows environment the assembly and its components from the old folder (Project A) to the new folder (Project B) and then add the Assembly A.A to the Assembly B and automaticaly the new Assembly A.A look for its components in folder B or a subfolder inside folder B (if previously Assembly A.A had is components inside a subfolder of project A). I have a problem trying to do the same with NX, because when I add assembly A.A in assembly B, the Assembly A.A is still linked to components in folder A and even renaming folder A doesn't solve the problem. I need to open the Assembly B with "as saved" load options because it also includes other components from other folders.
I have thought that I may clone Asembly A.A instead of copy it in windows explorer but I wanted to know if there is a better way of handling load options or a different recommended workflow in order to do this kind of things because if I clone Assembly A.A I lose subfolders structures or I lose links to external folders where I keep components that I don't manufacture myself like screws, nuts... and I prefer to store them out of project folder.
Thank you in advance.
