I agree with the 2V:1H with only adding to that the width of whatever applies the force. The slope of the load path starts at the edge of the applied load assuming the application material is stronger than plywood.
Also, I saw a plywood spacer years ago that had a repeating load on it. The area had some ponded water on it. Each time the load passed over it, an isolated area squeezed more water out than the adjacent area. It was about that same as the 2:1 cited here. The plywood was old but it appeared to be pressure treated so I assume it was similar to pine. Oak may be a little stiffer but I would not rely on that.
