pithpal
- Oct 21, 2005
- 50
Hi
I am doing a load survey for an office building for emergnency generator. The building is stuffed with computers and lot of unbalance as I can see when we measure current, here is an example:
Ia- 27.7 AMP
Ib- 9.25Amp
Ic- 15.25 Amp
120/208 V
I should go for load =Sqrt(3)* 208*27.7 cos(phi)
Now which current should I assume and what power factor .
One more thing to it, those duplex outlets, which are not being used right now, what load should I assign to them, as you know
each outlet is rated for (15 A, 120 V) and there are two receptacles in each outlet.
Ia- 27.7 AMP
Ib- 9.25Amp
Ic- 15.25 Amp
120/208 V
