Are there any fall protection engineers hanging out in here? I've been tasked with designing a "rope guide" for the safety line of a Controlled Descent Apparatus (CDA) for window cleaning/Exterior Building Maintenance (EBM). This is an isolated task for the fabricator of the guide - I am not designing the overall arrest system. The guide is a bent round bar welded to a flat mounting plate and attached to the top of the parapet, in order to re-position the safety/descent line to the correct location from an offset roof anchor.
The rope doesn't "anchor" to the rope guide, instead it passes through it and attaches to the roof anchor. Per the EBM designer who is responsible for the overall maintenance and arrest system, the hanging load on the line is 350 pounds, with a 900-pound impact load at fall arrest. They've given these loads as unfactored service level loads.
For the most part, the roof anchor and the safety line itself are required to resist 5,000 pounds. Is that true for things like parapets, building projections, guardrails, rope guides, etc that the line has to go over/around/through, but not actually anchor to?
