Hi Folks,
I am performing FEA analysis to investigate a fillet weld. My question is mostly regarding local failure (both elastic and elastic-plastic) as well as fatigue assessment (elastic method) based on ASME SEC VIII-Div 2-Part 5.
There is no machining on the weld, so weld toes are "Toe as-welded".
If I model the weld toe with sharp edge and no fillet radius it will create singularities. Is it any typical fillet radius to be used in FEA for fillet welds toes as they welded? Especially for checking local failure.
