1. While modelling two saddles for horizontal Shell & Tube Heat Exchangers in PV Elite, it is observed that the location of saddles is made with reference to Shell node and the total Tangent length is considered as total Shell length. Where as for vessel with two saddles, the Tangent length is the end to end tangent length and saddles are located with reference to that TL. Accordingly overhanging end channels are neglected for Heat Exchangers leading to unbalanced location of saddles with respect to Exchanger CG which accounts all parts end to end. Can this be elaborated.
1.1 Does 1/4 th. distance rule for location of saddles apply with respect to Shell nodes only and not for end to end TL of Total exchanher?
2. Calculations of saddle loads due to weight distribution of Exchanger not included. Can it be elaborated?
3. For many and almost all cases M2 of left saddle and right saddle has wide variation.
4. The principle of possible close matching of maximum negative and positive BM is mostly not achieved.
5. However, not withstanding the above, the stresses are within limits irrespective of saddles imbalanced location with respect to Exchanger CG. Is it suffice for design.
6. The BM diagram for the above circumstances does not appear to be appropriate. Can a BM diagram be included.
