Location of staircase construction joint
Syed Raabi
1
Hello Engineers
Below I have attached staircase formwork design and rebar design. Can anyone please suggest the best location for construction joint in this design and if not what additional structure will be required to add a construction joint in this design.
The situation is we have poured the column up-to the bottom of landing beam as of now and need your engineers idea on where to provide the construction joint.
  • CA003041011V00.pdf
  • CA003041012V00.pdf
