Loft between two surfaces in SolidWorks 2018
RobLN
152
Hi
I am new to SolidWorks and wondered if someone could advise on the creation of the following loft (see the word file)
I need to transition from a flat sketch to a 3D surface with a draft of 15 degrees but I cannot find the correct command.
Thank you.
Rob
Solid Edge; I-Deas 7 to 12; NX4 to NX8.5 / TeamCenter 9.1 & Ansys 14.5
 http://files.engineering.com/getfile.aspx?folder=9867c2e5-3ad8-4a6a-beb2-a7587264763b&file=loft.docx
You would probably be better off making that out os a series of surfaces because I don't see how you can do that as a single loft.
Scott Baugh, CSWP [pc2]
CAD Systems Manager
Evapar
"If it's not broke, Don't fix it!"
faq731-376
Hi
Thank you for the replies so far, in the meantime I have tried to 'knife and fork' it through using a cut sweep and then a larger rad to clean up the end result (although I would really need a chamfer in that area rather than a rad but the chamfer fails after the swept cut...) Towards the pointy end there is still a small mismatch coming from the draft command.
Here is the CAD attempt so far (SW v.2018...) , I'm open to any improvement suggestions :)
Thank you
Rob
 https://files.engineering.com/getfile.aspx?folder=5fd5cdba-5d74-4d50-99de-b1140563dea8&file=WRR_main_body.SLDPRT
