Hello Everyone,
I have a project in NYC where I have a huge roof in which we have a lot of long-span joists. We are preparing a load table for vulcraft and I have 2 questions about the loads.
1. Vulcraft asks for Live load end continuity Moments/Wind and Seismic end moments. We are already providing them uniform load and other point loads on the joist. My question here is - Why do they need these moments? We are already providing them with all uniform and point loads and the moment can easily be calculated right? I think they are still asking for this as the force collector joists will ultimately have more loads and they need to know that value - please correct me if I am wrong.
2. They also need Em values. From ASCE7-05 I found Em is (0.2*Sds*Dead Load) +/- (Overstrength factor*Seismic Load). If I use this for end moments, I have cases where dead load is positive and seismic is negative. Do we still give them the worst conservative value by considering seismic as positive. For eg - if following are your values - Dead Load Moment 10k-ft, Seismic Load Moment -30k-ft, Overstrength factor 3, Sds 0.3. Then in one case you will have 0.2*0.3*10 + 3*(-30) and then there is this case which is overly conservative 0.2*0.3*10 + 3*(30). I don't want to go ahead with conservative as I don't think that's right. But it would be really helpful if someone can advise me on this.
