cgstrucg
- Mar 21, 2018
- 135
I have a project in NYC for which I have a lot of long-span joists. I have a bunch of rooftop equipments on dunnage, posts of which rest on these joists. I have a few questions related to connections of these posts to the joists and if anyone can refer me in the right direction, it would be really helpful.
First is the post to joist connection. I was planning to just put a base plate at bottom of the post and drill bolts through the plate and joist flange to act as a pinned connection. Yesterday my senior engineer told me that he prefers weld. His reason was that he doesn't want to reduce the joist flange area. Now my question here is this that I always thought weld connection is always a rigid connection and moment will transfer through it as it resists rotation. But the senior engineer said that design welds to act so they don't transfer moment and I don't know how I can do that.
Second is regarding out of plane loads that equipment transfers to the bottom of the post. Vulcaraft doesn't design for these out of plane loads so the senior engineer asked me to look into sideways puddle weld to transfer the load to the roof diaphragm. For this, I really can't find any standard detail design and analysis. Has someone encountered these situations and please share with me details or any alternate concept.
The final thing is regarding those out of plane loads which we will transfer to the diaphragm. We have to figure out a way to transfer that diaphragm load to beams running perpendicular to the joists. Has anyone seen detail for this before? This is something for which I can't find any details which are simple and not warp the deck.
Any help would be really appreciated. I am designing roof with joists for the first time and although learning, it is quite challenging and I want to avoid designing small bad details that mess the roof.
Thanks a lot
Thanks a lot
