n8cole
Chemical
- Jun 24, 2024
- 29
I am a chemical engineer working on a spreadsheet that calculates heat capacity using the Joback method (see links below if you need more information on the Joback method). For this calculator, I am creating a database of chemical compounds and their functional groups, but it is taking too long. I tried using AI like Claude to help speed up the process, but it proved to be too unreliable. Is there another AI or resource I could use to quickly generate the functional groups of chemical compounds? My goal is to be able to feed the AI or resource a list of chemical compounds and have it output the functional groups in a format that is easy to copy and paste into my spreadsheet. I expect this might not be possible, and I may have to go back to the slow and painful process of doing it manually, but I figured it was worth a shot.
I have attached an example of how my spreadsheet database is going to look.
Also, I don't know if I am asking the right group.
- Joback Online Calculator: https://www.egichem.com/tools/calculators/joback/
- Jaback wiki page: https://en.wikipedia.org/wiki/Jobac...oback method is a,the sum of group parameters.
