Gte447f:
That’s a real head scratcher. Number 1, that horiz. offset is sure to collect moisture, even if no leaks, just from the potential moisture vapor collection in the vert. void spa. And, you’re right at the latitude here nobody know where to put the vapor barrier. I would say that there may be some damage, not too bad in nature, which can be fixed from the outside only. Is the wood still good, clean and solid, it can be wetted a few times in its life But, a good share of any serious moisture damage will involve interior work and refinishing also. And, the contractor and owner had better adjust their thinking to realize this. The real trick is to make this all as clean and simple as possible, since it must be done, and inconveniences a lot of people who didn’t cause the problem. Unfortunately, this is another one of those cases where the original Arch., builder, specialties contractors, owner, etc., the original geniuses who designed and built this edifice to architectural wonder, should be paying for the mess they made.
For starters, and since they are going to be removing (have removed) the ext. veneer, you should be looking for ways to pretty easily identify the extent of the damage from outside. This is, so you can define the extent and type of damage at each location, and the fix needed at that location. Study, understand and draw the bldg. detail at each location, for further understanding and fix study. Is it a bearing or nonbearing wall, jst. size and orientation, blocking, fl. and clg. conditions, etc. How does lateral load transfer take place at that current joint and your fix? Is there any consistency, so you can literally pick the spots from the outside veneer detail? I’ll bet that cant strip and offset at that fl. level is a big one. You should develop good clean new details for moisture and air movement barriers, flashings, etc. at all these various locations and on the bldg. in general. A veneer system made up of several different materials, different movements, flexibilities, stiffnesses, is just that much tougher to deal with, and flash/caulk at every material change or direction change.
At this stage of the game, you’re in a tough predicament, you didn’t make the mess, you are not a miracle worker, you are trying to make things as clean and simple, consistent with bldg. and health codes, as possible. And, your clients must determine to what level they wish to take the repair. I’m not suggesting leaving moldy sht. rock and carpet in place. Nor can you structurally tolerate spongy 2x’s or wall and fl. sheathing, but, if you stop the water and moisture condensation, you will pretty well solve the lesser problems. If you have significant mold issues, maybe it would be wise to talk with a mold abatement specialist to see what they can solve without total destruction.
