looking for vb journal critique
multicaduser
Industrial
Jan 29, 2013
261
Just trying to move from grip to vb journaling. Below is the code for my first try, no error checking yet, just got it functioning first. Looking for comments on the style of vb program writing being used, if there are better ways. No ide, just the journal editor in NX. All constructive criticism appreciated.
'NX 12
'Journal allows selection of file use type,
'rev level of file, and selection of objects
'to output for parasolid translation.
'Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main ()
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim currentPath As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim currentFile As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
Dim lw As ListingWindow = theSession.ListingWindow
Dim opType As String = ""
Dim opRevLevel As String = ""
Dim opFileName As String = ""
Dim mySelectedObjects() As NXObject
Dim myResponse As Selection.Response
Dim tagList() As NXOpen.Tag
Dim i As Integer = 0
opType = opChoice
opRevLevel = RevLevel
opFileName = (fileNamePieces(opType, opRevLevel, currentPath, currentFile))
myResponse = SelectObjects(mySelectedObjects)
If (myResponse = Selection.Response.Cancel) OrElse (myResponse = Selection.Response.Back) Then
'user canceled selection, exit journal
Exit Sub
End If
ReDim tagList(mySelectedObjects.GetUpperBound(0))
For i = 0 To mySelectedObjects.GetUpperBound(0)
tagList(i) = mySelectedObjects(i).Tag
'lw.WriteLine("object tag is: " & tagList(i))
Next
ufs.Ps.ExportData(tagList, opFileName & ".x_t")
lw.WriteLine("Output parasolid file name = " & opFileName & ".x_t")
ufs.Disp.CreateImage(opFileName & ".png", UFDisp.ImageFormat.Png, UFDisp.BackgroundColor.White)
lw.WriteLine("Output image file name = " & opFileName & ".png")
'theUfSession.Ui.UpdateListingWindow()
'Threading.Thread.Sleep(4000)
'lw.CloseWindow()
End Sub
'select operation type
Function opChoice() As String
lw.open()
Dim opList As New List(Of String)
opList.Add("electrode")
opList.Add("engraving")
opList.Add("surface")
opList.Add("wireframe")
Dim retVal As Integer = 0
Dim title As String = "Select file output type"
theUfSession.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
retVal = theUFSession.Ui.DisplayMenu(title, 1, opList.ToArray, opList.Count)
theUFSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
'1=back
'2=cancel
'5-18=menu item selected
'19=disallowed state, unable to bring up dialog
Select Case retVal
Case Is = 5
Return "electrode"
Case Is = 6
Return "engraving"
Case Is = 7
Return "surface"
Case Is = 8
Return "wireframe"
End Select
End Function
'select revision level
Function RevLevel()
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim retRev As String = ""
Dim RevList As New List(Of String)
revList.Add("None")
revList.Add("A")
revList.Add("B")
revList.Add("C")
revList.Add("D")
revList.Add("E")
revList.Add("F")
revList.Add("G")
Dim title As String = "Select Rev Level"
retVal = theUfSession.Ui.DisplayMenu(title, 1, revList.ToArray, revList.Count)
theUfSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
Select Case retVal
Case 5
retRev = ""
Case 6
retRev = "a"
Case 7
retRev = "b"
Case 8
retRev = "c"
Case 9
retRev = "d"
Case 10
retRev = "e"
Case 11
retRev = "f"
Case 12
retRev = "g"
End Select
If retRev <> "" Then
retRev = ("_rev_" & retRev)
End If
RETURN retRev
End Function
'select objects from the screen
Function SelectObjects(ByRef selobj() As NXObject) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim prompt as String = "Select Solid Bodies for export"
Dim title As String = "Selection"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = _
Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = _
Selection.SelectionScope.AnyInAssembly
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
Dim resp As Selection.Response = _
theUI.SelectionManager.SelectObjects( _
prompt, title, scope, selAction, _
includeFeatures, keepHighlighted, _
selectionMask_array, selobj)
Return resp
End Function
'file name function
Function fileNamePieces(opType As String, opRev As String, opPath As String, opFile As String)
Dim fullPath as string = ""
Dim pathPosition As Integer = 1
pathPosition = Instr(1,opPath, "CAD")
fullPath = ((Left(opPath, pathPosition-1)) & "CAM\" & opType & "\" & opFile & opRev)
Return fullPath
End Function
End Module
NX 12.0.1.7 Windows 10
Not a comment on your journal itself, but you should use the Code box function on this forum. Easier to read for the users.. :)
Code:
'NX 12
'Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main ()
opType = opChoice
Exit Sub
End If
Next
'lw.CloseWindow()
End Sub
lw.open()
'1=back
'2=cancel
Select Case retVal
Case Is = 5
Return "electrode"
Case Is = 6
Return "engraving"
Case Is = 7
Return "surface"
Case Is = 8
Return "wireframe"
End Select
End Function
Function RevLevel()
revList.Add("None")
revList.Add("A")
revList.Add("B")
revList.Add("C")
revList.Add("D")
revList.Add("E")
revList.Add("F")
revList.Add("G")
Select Case retVal
Case 5
retRev = ""
Case 6
retRev = "a"
Case 7
retRev = "b"
Case 8
retRev = "c"
Case 9
retRev = "d"
Case 10
retRev = "e"
Case 11
retRev = "f"
Case 12
retRev = "g"
End Select
End If
RETURN retRev
End Function
.Subtype = 0
End With
Return resp
End Function
'file name function
Return fullPath
End Function
End Module
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Thanks NutAce, wasn't aware of that.
Your code looks mostly OK, though I didn't read it very carefully. A few comments
(1) Use Option Infer On. It helps a lot.
(2) Don't use ReDim. It's very old-fashioned VB. Use lists, instead.
(3) Using List.AddRange would shorten your code in a couple of places
(4) It's usually a good idea to declare a variable and give it its initial value in the same line of code.
If you don't use an IDE, you're missing out on "intellisense", which is a *HUGE* benefit of VB versus GRIP.
There is a special manual to help people transition from GRIP to SNAP or NX/Open. You might find it useful. It's part of the standard NX doc collection.
Thanks BubbaK, just got through looking at examples of all your suggestions and I'm impressed. As a self taught programmer these are jewels to me.
As far as an IDE goes, I've tried to get one but the company won't shell out two bits to help me, but not automating is not an option so I teach myself and shrug off the inconvenience, after all, the best tool is the brain.
Thanks to all for the inputs.
Thanks cowski, what version of visual studio is compatible with NX12 and are there instructions on integrating it with NX?
That information can be found in the NX help product notes:
For NX 12 and a .net language, you will need the .net 4.5.1 and 4.6 framework installed. If you are running the code as a journal (uncompiled text file), it doesn't really matter what IDE you use as NX will compile the code right before running it.
C/C++ code is pretty picky about which compilers are compatible; .net languages much less so. Looks like Visual Studio 2015 is required for C/C++; you might want to stick with that for .net development just to be safe (assuming you are compiling your code to .dll or .exe files).
www.nxjournaling.com
You should probably read this post.
The two "Getting Started" guides mentioned there will give you a good introduction to SNAP or NX/Open. These guides contain tutorials that use the built-in Journal Editor and also Visual Studio (the free edition).
Debatable. For mundane rote tasks that don't require any creative thinking, a computer program like an IDE is arguably better than your brain, and is certainly better than my brain.
Awesome post to link to Bubbak. IDE's are great for the mundane tasks, but understanding the mundane tasks helps in trouble shooting. Going to read through the nxopen getting started before asking for vs express though.
Thanks for the inputs.
