Hi all! When I checked the information after model (ETABS) running my model, I found that the accuracy has been lost at couple of points. Can you please let me know what might be the reason and how to eliminate this? It is happening at the joint close to joist framing to a shear wall. Two closes joint (see figure) has the distance 0.075 ft in between.
