Thank you in advance.
Not sure if this is the proper way to address this. Don't know if this is a MARKER??? issue, or WHAT it would be called in Solidworks.
I am opening up files and seems 90% of my work is all of a sudden incorrect. It is like Solidworks is pulling files in most of my assembly from the WRONG directories.
Is there a way to remedy this? Maybe my cache needs to be cleaned up or something. I wasn't having a problem before, but ALL of a sudden. Not sure if there is a setting that CLEARS cache EVERY TIME you start Solidworks.
I am working off a Solidworks Workgroup PDM vault, plus my personal Drive, NOW, the Admin has created ANOTHER Vault. Seems 3 different Vaults to work with.
The Administrator very much enjoys us to PACK AND GO assemblies when we need to make a new version or update, then save the new version in a NEW folder. To me, this seems it would disconnect the assemblies. Rather I would feel configurations is the way to go. NOT sure if all this PACK AND GO is my problem.
HELP!!!
HELP!!!
