structSU10
- Mar 3, 2011
- 1,062
I have a situation where the design concrete mix was 4000 PSI, with 145 pcf density - pretty standard mix, with components as follows:
cement 520 lbs
fly ash 91 lbs
water 32 gals
fine agg 1220 lbs
coarse agg 1760 lbs
WRA - 12.2 oz sika plastocrete
There was an issue with the concrete in the field, with strengths coming back on cylinders of 2000 PSI, and the laboratory test came back at 125-128 pcf density. The contractor took cores to test the concrete in place, and a couple cores had the 128 pcf density, and strength about 3000 psi, and one have density of 136 pcf and strength of 4500 psi.
These elements, for strength, require a minimum of 3000 psi. Do I rely on the concrete cores that I have adequate strength and can accept the concrete as placed? Should I be concerned about quality of concrete away from the cores and the cylinder results?
cement 520 lbs
fly ash 91 lbs
water 32 gals
fine agg 1220 lbs
coarse agg 1760 lbs
